Hello, it is the first time that I hope I hope your problem is that my Honda Odyssey when the wiper work well but when it comes to turn off or put them intermittent they do not work if I turn them off they go out in the middle of the glass or where the flashing does not work it takes it to the mechanic I charge me $ 50.00 dollars and tells me that it does not know that it can be the box of the fuses that the driver is winged. At the head of the engine I take away a relay I do not know what to do since not exactly what you have to buy
Hello everyone, Heberpr, the Wiper or Windshield Windshield Function is conroat relays). The scanner or electronic diagnosis is going to server where to look for the failure, in any case in similar poor poor, I have observed, dirt or wear of the coals or brushes of the engine of the windshield wiper, because the quality of the electronics and the wiring in those deep body electronics. If you have any warning doubts. Cordial Sales.
Hello, in addition to the recommendations of fellow Fiat ", check that the contactors of the command or lever work well (continuity test) because with the use they are wearing and makes false contacts. Greetings !!
