Technical question
11 years 4 months before - 11 years 4 months before #45453 by manual-mecanica
Technical question published by Manual-Mecanica
Hello friends I have a Renault Laguna 2.2 dci and my query is as follows: After taking out the box where the air filter is hosted I have had to disconnect some engine connectors and after assembling and connecting everything, the engine does not start.
Some of you know how to remove a fault code or if any of you had a similar problem, I would appreciate your comments.
All the best
Last edition: 11 years 4 months before by .
11 years 4 months before #45464 by manual-mecanica
Manual-Mecanica Answer on the topic Technical Question
Hi Alfredo2264, it happened to me that sometimes I have had to step on the clutch and brake pedal at the same time, to be able to start it ...? Try to see, but if you get some code (eg of the CKP or injector ring) sensor may not start (if any of these is evil). Greetings!!
