Another technical question
11 years 4 months before #45465 by manual-mecanica
Another technical question published by Manual-Mecanica
I have a Renault Laguna 2.2 dci and I have a fault code and the engine does not start.
My question is and if any of you can confirm that disconnecting a minute the negative of the Beteria the error takes off, thanks for your comments.
11 years 4 months before #45468 by manual-mecanica
Manual-Mecanica Answer on the subject Another technical question
Surely no. But there is nothing to try.
If it does not start you, I do not think that only the failure is registered, something broken must be.
Does the Gasoil steps do I have? reaches the engine? Distribution belt well? air in the diesel circuit?
put a scanner and with what I put on you already know where to look.
11 years 4 months before #45469 by manual-mecanica
The failure is usually removed when you change or repair the damaged component (a plug, sensor, etc ...) but to erase the memory memory I think the "clip" program of Renault should be used ... as well as the partner Igryo, if you tell us the error number, we can help you.
