Dodge Neon Standar 2.0 Soch accelerates but does not advance
11 years 4 months before #45470 by manual-mecanica
Being neutral or speed when stepping on the thorough accelerator, it only reaches 2000 rpm, from 1st. up to 5a. It does the same, progress but until the 2000 rpm there you keep the needle, and the rugid of the accelerated motor to the maximum is heard when stepping in depth, but the needle does not exceed 2000, it can walk but very slow Of so many expenses, now the last electric told me that it was a mechanical question that was the cluch kit, and the mechanic tells me that the problem is electric, which does not guarantee me if the Cluch kit is also changed that would be a more expense to everything, thanks in advance for your help
11 years 4 months before #45472 by manual-mecanica
Hello friend, look, I create without a doubt that you have spent the Embreague album and better do not use the car until you change it because you could also spoil the press.
11 years 4 months before #45484 by manual-mecanica
With more details I could help you because with what I have read without a doubt I would also think that you need to replace the clutch kit but you have scanned the vehicle that DTCS presents, the check -up witness remains on or Service Engine Soon as I said with more details could help more.
Greetings from Nicaragua.
11 years 4 months before #45637 by manual-mecanica
Out of curiosity I ask: when you say you step thoroughly; really the engine climbs in revolutions?
That is to say according to the revolutions of the, engine rise to the maximum or near there?
One thing is that you accelerate thoroughly and the engine only rises up to 2000rpm, so it supposes and depending on the ECU or ECM or computer, it protects the engine to those rpm, to protect it from any existing damage (see anterior theme of the check snack)
something serious that the engine really rises in RPM (example to 5500) and the vehicle progresses precariously. Here if we could say that the clutch skates or not effectively couples.-
We can also assume that the feeding (air and fuel mixture) is poor from 2000rpm, which would be flour from another sack.-
Investigate a little, to be able to help you:-
Luck and greetings.-
