Spark 2010 car heating
11 years 4 months before #45499 by manual-mecanica
Spark 2010 car heating posted by Manual-Mecanica
Greetings, last week I was on the highway and I broke the container of the 2010 spark car refrigerant, as I had the air off I did not notice the heating the car and it is heated until automatically turned off,
I know that I must change the deposit of the refrigerant but I would like to know that he advises that I check to know if something more suffered a consequence
thanks for your support for your support
11 years 4 months before #45500 by manual-mecanica
Manual-Mecanica Response on the topic Cum Heating SPARK 2010
Hello argenisrv, what you should look at when you fill and purge the air to the circuit, it is to see if it consumes water in the course of a few days, and see if the water and oil are not mixed (you will see it for the color of this, it becomes whitish), if one of these two things happens to you, the button of the cylinder head has been damaged and there will be no other remedy to change it in addition to changing it. of cylinder head. Luck!!!
*It is very important to stop as soon as possible, so that these problems do not happen, if for example. We notice that it does not mark temperature or the cold air comes out in hot position .... the engine may not have water
