Jeep Wrangler CRD
11 years 4 months before #45541 by manual-mecanica
Jeep Wrangler CRD published by Manual-Mecanica
estimated install cruise speed in the JEEP and this must be activated in the ECU, as I can do, I have the cable and the Gelletto 1260 software, another software is needed or you can with this
11 years 4 months before #45643 by manual-mecanica
Manual-Mecanica Answer on the subject Jeep Wrangler CRD
Hi atododos, Manuel197, so the cooking sotware is for European cars, to activate the communication Can between the engine control module and the Cruise Control ECU, a procedure for pairing and recognition of the cruster speed control module through the scanner Drb 3 Chrysler-Jeep. Good luck and greetings cordials.
