Open Hyundai rear back door solved
11 years 3 months before - 11 years 3 months before #45843 by manual-mecanica
Open Hyundai rear door solved by manual-mecanica
Hello everyone
I have a Hyundai Accent of 98 The problem is the rear right door I did not open outside and I have the children's lock (safety) so that I cannot open either inside or on the outside, I can not remove the panel with the closed door, I have removed the inner handle but no matter how much the rod's shot does not do anything it seems stuck, it will be for the safety latch.
Some help please.
Thank you
Last edition: 11 years 3 months before by .
11 years 3 months before #45846 by manual-mecanica
Manual-Mecanica Answer on the topic Open Right Hyundai Door
Hello, you will have to loosen the hinged screws if you can, from the central fence, to be able to separate it a little and put your finger to unlock the safety closure ... or "make a broken" to the panel, if it does not come out pulling it, by the closure. Take it quiet so as not to do any strip, or try to see if you can make some hook to remove the insurance forcing the door a little, I can't think of anything else. Luck!!
11 years 3 months before #45847 by manual-mecanica
After maybe you can also try disassembling the rear wheel pass if you can disassemble the closing hook, but you can only in some ...
11 years 3 months before #45849 by manual-mecanica
Gracis Ismael 53
I have thought about removing the in midst of the 2 doors to remove the hinge or do what you say for the wheel arc, also what I am going to do is remove the small glass and put something to pull up the latch or something if it opens.
Well I'll have this weekend.
I think that in the end you will leave panel you will see.
greetings
11 years 3 months before #45892 by manual-mecanica
Well thanks to everyone
I have removed a rubber from the panel that goes next to the glass. And little by little pulling and forcing the panel I podium put my hand and pull the rod to open.
Thank you.
