Hello everyone, this is a question that I have been doing for some time to see if any of you know something about the subject and serve as clarification, the question is: knowing if the engine needs a lower dosing when the EGR is open, or on the contrary ... or the dose is independent of the EGR operation and does not affect the recirculation of gases both as for varying the dosing ... All these questions come after having annulled the EG , no temperature increase in the refigentant, but surely if the temperature of the exhaust gas is greater, since the catalyst housing has changed color ... Nor does consumption or decreased increase, the exhaust ducts of the cylinder
head (Especially for the topic of grease ..), Although the engine is going very well, I will undo the changes (and again dirty the admission) open the step to the EGR, because I am not sure that it would happen to the oil or the catalyst with such a temperature in escape ... Ideas/opinions are appreciated ... Greetings !!!
