Hyundai Excel 91 does not start
11 years 2 months before #46066 by manual-mecanica
Hyundai Excel 91 does not start published by Manual-Mecanica
Good evening colleagues I have a particular case of a Hyundai Excel 91 which does not start the issue is that it has adequate fuel pressure new pump together with the pressure regulator, the computer is also the vehicle also has a spark and the injectors were cleaning, they throw well the gasoline also has good engine compression, the distribution is fine but the distributor is removed several times to see if this is the damage. mind started but when it accelerated it did not respond and went out until it no longer wanted to start anymore, I appreciate any contribution or help of your invaluable knowledge no longer I know what to do :(
