Opel Vectra B 1.7 TD pump change
11 years 2 months before #46068 by manual-mecanica
Opel Vectra B 1.7 TD pump change published by Manual-Mecanica
The pump is easy to change the straps are removed: loosening the upper tensioner and remove the long strap then loosen the pump screws to release the pulley and so the other two straps are removed then we change the pump and mounted the straps with the pulley and it is simple
