Mitsubishi L200 Position lights
11 years 1 month before #46171 by manual-mecanica
Mitsubishi L200 Position lights published by Manual-Mecanica
Hello, how are you ???
I got a Mitsubishi L200 truck
when the brake pedal
on the position lights
that can be?
Can it be a bad land of a cable?
The brake light switch?
At least the fuses look good
I expect your advice in advance thank you very much chau
11 years 1 month before #46180 by manual-mecanica
Manual-Mecanica response on the topic Mitsubishi L200 position lights
Good Morning from Grece. Check The Ground Wire.
Check for a short. Check The Bulbs.
