CODATE E36 316I 1900 105CV
10 years 11 months before #46688 by manual-mecanica
CODATE E36 316I 1900 105CV Published by Manual-Mecanica
Hello, I am a new greeting for everyone, I have made a binding of the car but saves does not circulate the water through the engine someone can advise me because it can happen, if the thermostat or for another reason that is missing to purge. The motor car works well but the temperature rises.
10 years 11 months before #46689 by manual-mecanica
Manual-Mecanica Response on the Cuine E36 316i 1900 105CV
Welcome to the forum! The first thing to look at is whether the thermostat works well or you put it new, if it does not open when it heats, that the circuit is well purged and an important thing is that the fan works when it reaches its temperature (whether electric or viscous coupling). If I burn the board before, you have to know why I did it, if not, you risk it again. Check the sleeves, that the water pump works, and the radiator is clean, and that the heating radiator has no leaks, but above all the thermostat. Greetings!!
