KIA CERATO 2005
10 years 9 months before #47458 by manual-mecanica
KIA CERATO 2005 Published by Manual-Mecanica
Maybe someone who can help me with the Kia Cerato Electric Manual 2005 2.0
10 years 8 months before #47460 by manual-mecanica
Manual-Mecanica Response on the subject Kia Cerato 2005
Javier:
I do not have the manual of the KIA Cerato 2.0L 2005, but I have any knowledge of the diagnosis and a bibliography of the Hyundai, which is a "relative" quite close to the Kia.
I would need to help you tell me some things, when do you comment on the vehicle speed sensor (VSS), is it because it already gave you as DTC fault code? Or is that you suppose that sensor, besides what are the symptoms of the vehicle? If you can answer me to see if I can help you
greetings
10 years 8 months before #47466 by manual-mecanica
Thanks for answering.
Mi Kia Cerato has the problem that the speed signal does not reach the ECU, but the velocimetro and the odomoetro work properly, the Scaner reports speed sensor, the VVS sensor is already changed, but the fault persists. What I would like to know is whether the sensor signal is sent directly to the ECU, or from which part of the speed signal since Pin of the ECU, to be able to check. thank you. Cheng light is still on and the Scaner continues to report sensor fault VVS.
