Renault Megane¿Caracteristicas Tecnicas Nº Vins?
10 years 7 months before #48071 by manual-mecanica
Greetings to all the foreros:
I have given me a renault megane type Ba variant beon and I need to buy some spare parts but I do not know how many CV and if it is D. Td. TDI etc
The Vens is VF1BA0NM519847555
The car is from Gas-Oc Motor D/F9Q A7 of 1870cc
can someone tell me the characteristics of the engine or where to look for them to buy the spare parts because there are so many models and displacements that I do not want to put the leg.
Greetings to all
10 years 7 months before #48072 by manual-mecanica
This one is not mistaken 120 hp, it is direct "DTI" injection (it has some small variants between the F9Q of the Lagoon, due to the position where the turbo goes and some airpiration plastic tubes and little more). Motor F9Q 800 Monta El Megane, Diameter 80 X 93 Carrera, Compression 19 to 1, high pressure pump and Bosch injectors. You can find the injection and filter pieces in any spare parts store, but other concrete will have to be in Renault and carrying the vast number you will have no problem. Greetings!!
