C2
10 years 2 months before #49033 by manual-mecanica
C2 Published by Manual-Mecanica
Let's see if someone can give me an idea of ​​why my C2 does not start, I stop the car and the following aldia does not want to start the mechanic tells me that they are the starting coils are put and the car is still the same I get a message in the display of the radio protected by minimum consumption or something like that
10 years 2 months before #49034 by manual-mecanica
Manual-Mecanica Response on topic C2
You checked fuel level, oil, water? According to the message is a consumption.
10 years 2 months before #49038 by manual-mecanica
Hello Agurel, minimal consumption or fuel savings mode or energy can be the subject of the BSI ("intelligent" services) that carries in the motor compartment, sometimes due to low battery charge, it does not let this or also a bad contact in the positive feeding of the positive in one of the input fuses, which review this to see. Be careful that of problems that these Bsi give .. !! Greetings!!
