Problems in 4 x4 newly repaired dentarea.
10 years 4 days before #49503 by manual-mecanica
Problems in 4 x4 newly repaired dentarea. Posted by manual-mecanica
Hello, I greet you and I make the following consultation: I had problems with the homokinetic of the 4 x 4 front of my great Cherokee Limited year 1997, it maintains permanent traction on the wheels. I bought the repair they installed it but the problems began: I made a 1209 km trip and returned and presented the following signals:
it began to sound underway with very strong noise (as damaged dough), then when using brakes it was hard for me to apply them and later I did not answer me. In those kilometers the normal fuel spending is a misery, but this time he comsumed all the fuel, and not to damage pieces again. Now I drive without traction.
I revived Palier axles, etc.uffer all well. Homocinetic set, cardan well.
It will be that he settled badly, he has some position, since, they did it in a local workshop, and now I dare not take them to avoid damaging pieces.
You can advise me. I appreciate them.
Bafo
10 years 4 days before #49505 by manual-mecanica
Manual-Mecanica response on the topic 4 x4 of recently repaired.
Hello, if only homocinetic changing, you should not have problems, but if they repaired the front differential, the gear relationships are probably not equal to the one before, connect it, levatals two wheels one of each axis marks a reference and you have touches 10 laps one of the wheels and fixed if the other axis also gives the same laps, that discusses that the measure of the wheels are equal, ....
