cooling system
9 years 11 months before #49567 by manual-mecanica
Cooling system published by Manual-Mecanica
I have a model 98 I have several days that he is heating, I have checked it and I see that he throws the radiator's water for the antifreeze deposit, in addition that he is getting too much, the radiator has changed, the cap put it original, I changed the water pump, they also changed the time band and remains the same or worse or worse, it can be, it can be, help with their comments.
Nothing from the water of the radiator also does not return, already check it and does not have refrigerant leaks. aid
9 years 11 months before #49569 by manual-mecanica
Manual-Mecanica Response on the topic cooling system
Change the butt packing
9 years 11 months before #49701 by manual-mecanica
I already changed the packaging the car thanks
