Honda CRV 2000 Compression
9 years 11 months before #49699 by manual-mecanica
Honda CRV 2000 Compression Published by Manual-Mecanica
Hello good!!
Could someone tell me if due to a decompression does the vehicle start?
It is four cylinders, in cylinder 1 the compression is 120 psi, cylinder 2 has 120 psi, cylinder 3 varies of 80-90 psi and cylinder 4 equal 80-90 psi.
It is going but it does not start, it is cool spark and fuel, there is no failure of ignition or coil.
9 years 11 months before #49700 by manual-mecanica
Manual-Mecanica Response on the Honda CRV 2000 Compression
Of course, a decompression produces ignition failures ,,,, This decompression can occur due to a poor valve setting or that the valves do not make good stamp in their seat and finally of the cases broken or glued wheels
9 years 10 months before #49705 by manual-mecanica
Hello, here I give you a fact so that you support yourself in the normal citation must have 15Bar (217 Libra) The minimum is 9.5 bar (135 pounds) although personally with 120 pounds there are engines that turn on but with certain failures without strength and consumption of oil. I hope the data serves you greetings.
