Ibiza Distribution Correa
9 years 5 months before #50566 by manual-mecanica
Ibiza distribution strap published by Manual-Mecanica
Hello everyone. Wait for help from your part.
I am trying to change the distribution belt of my old man (and cascado) Ibiza of 1997 MPI of 1.4 60 hp. I have removed the alternator's strap (it has no assisted address) and the protective cover of the belt itself and the crankshaft pulley. I do not have the key to get the spark plug number one. Could anyone know me the measure to buy it? I do not have very clear how the following I have to do. The tree pulley does not have draft marks and the crankshaft piñon has a bulky dot and I am not sure that I have to align. Could anyone "enlighten me" and explain the procedure to follow a bit?
Thanks in advance ..
9 years 5 months before #50569 by manual-mecanica
Manual-Mecanica response on the topic Correa Distribution of Ibiza
The motor time scheme these two appear in my data I hope you serve you, greetings.
9 years 5 months before #50572 by manual-mecanica
Thanks Sorto. The second is the good. I will put me with this scheme.
9 years 5 months before #50580 by manual-mecanica
Again here. I took the belt but although I thought it would not be necessary, I will have to remove the camshaft pulley. Does anyone know if the thread is right or left? It seems nonsense but it is quite tight and I am not sure what the right sense is.
thank you
