DTC P0336 without solution ...
8 years 5 months before #52002 by manual-mecanica
DTC P0336 without solution ... published by manual-mecanica
Cordial greeting, I have an Optra Limited black lid, which leaves me intermittent the pulse of coil 1 and 4 as if it were welding with an electrode, the engine is difficult to turn on, in doing so they are failing cylinders due Coil, and Rich Crown so far I have not obtained a solution, another computer, CKP, CMP, coil ... Any opinion I will be grateful ... will also be proven ...
8 years 5 months before #52009 by manual-mecanica
Manual-Mecanica response on the topic DTC P0336 without solution ...
Hello. The P0336 code is not easy to solve .... it indicates that the ECU does not like the signal or rando of the CKP. In general, such failure can be diagnosed with oscilloscope and experience. SL2
