Saturn 1.9 16v 96 ignition failure.
8 years 2 months before #52205 by manual-mecanica
Saturn 1.9 16v 96 ignition failure. Posted by manual-mecanica
The crankshaft is changed and no longer turns on explosions, it burns too much gasoline, works with 2 spark plugs and exchanges. The behavior is a synchronization failure but it is already checked a multitude of times and is fine, the crankshaft position sensor works well.
8 years 2 months before #52207 by manual-mecanica
Manual-Mecanica response on the subject Saturn 1.9 16V 96 ignition failure.
You should compare well the crankshaft with which it brought perhaps it is not the same number and the raccocutor was different.
It seems to me that there are for doh and for Soch
8 years 1 month before #52211 by manual-mecanica
Ok, thank you.
