Good morning! I have an Accent 98 1.3L bought in my country (in those years they were supposed to take away the DLC so that you have when you have problems with your vehicle) well the years have passed and I have already acquired cocnocimient My 327 scanner connects to all of them ....... Look for information from mine and find the pinout of the ECU of mine 55 pins and found a 9 -pin connector that carried the sensor groun, l and k and another 2 more that I have not identified that I imagine that they are airbad and signal of the vs. 8 And Groun sensor to 5 ... Then the chassis tie 4 and +12 of the battery to 16 without managing to connect with about 10 applications the most powerful without result of connection any suggestion will be my Scaner that cannot connect with this type of ECU? Also connect to the ground to have activates diagnosis by the focus of check without any result.
