I can't open the Fiat Siena-Palio manual
16 years 2 weeks before #8284 By manual-workshop
Manual-workshop response on the Re: I can't open the Fiat Siena-Palio manual
You simply have the extension .iso to the ACDSEE. The extensions assigned to programs are often hidden automatically and do not appear. Why don't you follow the instructions I gave you instead of spinning whether or not you have extension? You will see that if you do it works perfectly.
16 years 2 weeks before #8306 by manual-mecanica
Manual-Mecanica Answer on the Re: I can't open the Fiat Siena-Palio manual
Everything is fine! I could already open the ISO file, you can see the mechanics manual well, thank you very much.
16 years 2 weeks before #8339 by manual-mecanica
Hello, how are you?
Please I can't go down, I was reading the steps to follow but I don't achieve it
What am I doing wrong
greetings...: S
16 years 1 week before #8395 By manual-workshop
Probably nothing, there are countries especially from the south of America whose access suppliers have very bad connections with Europe and cut off the file. To make an idea of ​​how the downloads should go for connections greater than 3 mbits/s should download about 250 kbytes/s. You just have to erase the cache from the browser and try again to discharge from the file.
16 years 1 week before #8401 by manual-mecanica
How about, thank you for your answer ...
I find myself in Argentina, Bs.As. It must then be what you say, because under and again and there is no case. I can't have had it.
In all ways thank you very much ...
greetings ...
