- Thanks received: 1
06-19-2025 Hits: 493 Technology
Hello friend, your problem is corrected by changing the clutch pump or also called an emitter that is the one that is operated by the clutch pedal, the clutch bombin or also called receiver is the one that goes inside the clutch but as you say that they changed it months ago because they should have put it Nevo. If at the moment the pump is to work.
