Hello everyone,
In the first place I would like to thank everyone who is improlled on this page and that thanks to you we can solve the occasional problem with cars, sincerely thanks.
I tell you that it has happened to my matrix and if it is possible that you give me any solution:
On a trip to Salamanca, just when we were arriving a noise that came from under the car. On the back the car stopped suddenly on the highway but I managed to boot it. He took it to the official dealership where they told me that the low pump had been spoiled inside the diesel deposit because this deposit began to discarded the paint or the coating that carries inner since the tank is of sheet metal and the gas filter must also be wandered.
I found the explanation a bit weird and before riding it I went to the size to see it myself. The deposit seemed that the completely clogged low bomb pump was actually being discharged. They told me that it was € 1030 that I don't have and I told them to ride it again. Once on the street I clean the bomb and worked perfectly until today it has stopped and I think it is an injector that must have been managed. I have the new deposit in the car but I haven't had time to change it.
My question is that I have seen several problems on the Internet regarding the injectors of the Matrix and that if the breakdown will not come for a failure in the deposit that should be plastic.
The second issue is whether someone can pass by the Matrix Crdi since I am going to change it in the company Car and You that you do it.
My email is
Greetings, and I repeat thanks for everything.
