Help me find a Fordour 99 manual
15 years 2 months before #12933 by manual-mecanica
Help me find a Fordour 99 manual published by Manual-Mecanica
Very good afternoon mechanical friends of the entire Republic I have a problem with a Fentour The fault is that there is a spark and there is pulsation but does not turn on the ship to the time band is in its brands as it is of being and if it has compression in the cylinders I would like someone to help me find the mechanic manual of a 1999 model contour to know rather where I Mechanic ...
thanks for giving the time to read these lines ...
by the way how I can share manuals since I have several that I do not have here I am new in this forum and I would like to contribute ...
15 years 2 months before #12959 by manual-mecanica
Manual-Mecanica Answer on the Re: Help me find a Fordour 99 manual
Hello.
In the Rapidshare search engine you write down the manual you are looking for and several will appear. I hope it helps you.
15 years 2 months before #12969 by manual-mecanica
ok leave me try to see if I am successful ;) ;)
15 years 2 months before #12982 by manual-mecanica
In the Ford section you find that of the 2000 escort in Mexico, the two models are similar The manual that tells you is like the one in the Ford section but your fault may be lack of fuel in the Czech injectors your alarm or the fuel cut switch.
15 years 2 months before #12991 by manual-mecanica
In fact that is what is check what is the alarm and what are pulses in injectors everything is fine of echo remove the rail of injectors and the cheke outside and everyone does the same I went on the compression side and these is what gives me ...
Cylinder No. 1: 46 lbs
Cylinder No. 2: 75 lbs
Cylinder No. 3: 115 LBS
Cylinder No. 4: 65 lbs
The client tells me that the car works perfectly well before presenting the fault one night the focus Engine was turned on
.B)
