Golf 93 Closter does not work Tacometro and RPM
15 years 1 month before - 15 years 1 month before #13337 by manual-mecanica
Hello I have a 93 golf and I stop working the closter and the rpm of the dashboard the battery lights, alternator, high lights, and the mileage marker, but if the gasoline and temperature markers work and turn on the board lights thanks beforehand !!
Latest edition: 15 years 1 month before by .
15 years 1 month before #13358 by manual-mecanica
Well first of all, I descend if you checked the fuses as the first step in one of those I know that some fuses of your vehicle if you already did the cabling of your vehicle since it can be making it by somewhere of the body and the other sees the land cable that your vehicle carries that is coupled in the gearbox that is well tight
15 years 1 month before #13430 by manual-mecanica
Hello, do not scare yourself, the closter of the A3 left defective and after several years they stop working, you have to change it, more or less cost you 1000 pesos used. If you are interested, I can sell you one to sell used parts.
