Ebro L80 truck (turbo)
14 years 7 months before #17543 by manual-mecanica
Ebro L80 (Turbo) truck published by Manual-Mecanica
I am looking for the workshop or exploded manual of an L80 Ebro truck.
It has been stopped for a few years and the brakes or engine strike do not work.
If anyone can help me?
Thank you so much
14 years 5 months before #18862 by manual-mecanica
Manual-Mecanica Response on the Re: Ebro L80 Truck (Turbo)
If you have the brake look that you do not miss oil (dot4) and in each wheel you have a pothogue stains the brake several times and you hold it treaded (2pers are required) Inhabitants the wandering that comes out all the air and close you start again.
The motor brake with the truck runs off the tube and operates the brake and comes out air if it does not check the fuses
14 years 4 months before #18996 by manual-mecanica
Hello, you will see my opinion is that the depression fails This model the motor stop can work under empty wants to say that the depressor or the master does not work well greetings
