Hello, first of all, thank who can throw a cable in advance, it is my first question in the forum, a greeting for everyone and if I can lend a hand do not hesitate, because it turns out that a Ford Transit of 98.2.5 Td has reached my hands with problems that the turbo does not act, I lose diesel by the injection bomb, you turn off the furbone once started and still running as about 15 more, you could see if you could see if you could see if The theme or spend the manual if someone has ede, thanks and greetings, you do an excellent job.
