Alarm problems
14 years 3 months before #19975 by manual-mecanica
Alarms problems published by Manual-Mecanica
I need to know if someone can help me how to deactivate carlarms. Montero Mitsubichi 96 truck I don't know what to do I hope someone can help me.
THANK YOU
14 years 3 months before #19976 by manual-mecanica
Manual-Mecanica Response on the Re: Alarm Problems
Hello German76, you just have to disconnect the alarm cable deck and check that the car is started, but starts the thing, you would have to take it to an electrical workshop.
14 years 3 months before #19978 by manual-mecanica
Ok thanks I already did it, however, the car continues to light and turns off, look at the intermittent one can be launched walk and all without problems the only problem is the flash of all the lights as if it were connected
14 years 3 months before #19979 by manual-mecanica
It seems to me that you are not disconnecting the cable deck, I do not mean disconnecting the alarm with the key that brings but to remove an electrical connector that has several cable, is usually hidden by a rubber dump so that it does not wet, locate said connector and unleashed of the alarm box, luck.
