If your problem is to know where the thermostat is located,
the solution is from the radiator there are two hoses (hoses) the one that connects with the thermostat
that is of course attached to the engine and the one below is the one
that connects the water pump that is also placed to the engine of the engine what you have to do is to be the hose that indicates you to follow them until you reach the engine
