PEUGOOT ELECTRIC DIAGRAME
14 years 2 months before #20694 by manual-mecanica
PEUGOOT ELECTRIC DIAGRAME PUBLISHED BY MANUAL-MECANICA
:( Estimated thanks for all the data provided in this group, I am complicated with my peugeot 206 model ROLAD GARROS year 2000 I need the electrical diagram of the model I am with my lion stop That I cannot find favor someone can help me, since Ecu nine is very expensive and there is no insurance that needs to change it and or to be sure to help your help.
14 years 2 months before #20697 by manual-mecanica
Manual-Mecanica Answer on the Re: PEUGOOT ELECTRIC DIAGRAME
What fails you make the leon
14 years 2 months before #20700 by manual-mecanica
It stopped on the road and did not start anymore, a mechanic helped me that I checked the motor part fuel etc .. and I had to tow the city where it takes it to an electromechanical that I checked the entire elcertric system and connected it to the scanner but I did not connect it to take it out of that workshop because the mechanic told me that it did not know what could be what another was carried out with another scan. Scanner will connect the ECU and the same will take it to another ElctromeCanica workshop to review all the tanks to see if there was a deconed sensor or something that is not the ECU and tells me that it is the computer, but then consulting or another person by phon With diagram of the model the one that does not come in the car manual since the ECU would connect even if it was bad that is to say it is commected but with errors
14 years 2 months before #20701 by manual-mecanica
Hello, I need to know what motor it has and what brand and model is the ECU so I pass your scheme since it can be iaw, bosch or sagen greetings
14 years 2 months before #20708 by manual-mecanica
Estimated, the ECU brand is Bosch 261 206 216 MP7.2, the engine is 1.6 year 2000, thanks for all its help.
