Peugeot 207 Workshop Manual
14 years 3 days before - 14 years 3 days before #23116 by manual-mecanica
Peugeot 207 Workshop Manual published by Manual-Mecanica
Hello everyone:
I am making a montage for my car, a Peugeot 207 Sport and I need to make several interconnections. To do this I need a 12V tension that is not cut with the key or with low intensity energy saving mode. I also need 12V of more intensity 2-4 amps that is cut with the key. Can you help me ?? I suppose that with the workshop manual I could get something clear.
Thank you very much to everyone.
Last edition: 14 years 3 days before by .
13 years 9 months before #25563 by manual-mecanica
Manual-Mecanica Response on the Re: Peugeot 207 Workshop Manual
-Hi, friend.
I would recommend that you make the connection of 30 (direct battery terminal) to the cable that enters directly to the fuse box. When you have taken the cable you want, put your protection by fuses and once there everything ready. I do not recommend cables from a less than 0.75mm section.
Do not connect in parallel or in series what you make to do with another module or circuit. It could generate tension drops that interife in the proper functioning of a control unit and appears breakdowns of that type.
All the best.
13 years 9 months before #25565 by manual-mecanica
Thanks for the answer. What I am missing are the schemes to find the connection points. The truth is that I give me a lot of respect to touch the battery and the fuse box.
