Renault Clio Manual
13 years 11 months before #23910 by manual-mecanica
Renault Clio Manual published by Manual-Mecanica
Hello everyone, I need the Renault Clio Year year 2002 Motor 1.6 since it was giving me very little mileage for benzina ... If someone can help me I would appreciate it.
thank you
13 years 11 months before #23913 by manual-mecanica
Manual-Mecanica Answer on the Renault Clio Manual
Hello, check several things in your vehicle before making larger disruptions, I suggest you:
1- With the help of a gas analyzer, check that the CO2 is in a value greater than 12 or 13 ppm (the greater the value is better the combustion), that the values ​​of CO and O2, are as low as possible and their values ​​are related (as close to 0 possible and that their vaalors are very proxim CO value is greater than that of O2, there is greater consumption of gasoline, if on the contrary it is the O2 that is higher you have a poor mixture.
You must check the state of the spark plugs (those of platinum are better) and the spark plug cables, that the air filter is not very dirty, that there are no fault codes present in your vehicle (Check Engine light light on the vehicle's board, consult its location in the owner's manual).
That is a good start to have a good time, if this does not work, I give you more checkpoints, this is the basic.
Greetings
13 years 11 months before #23916 by manual-mecanica
Look at the most common problem in this type of engines is that the coils are easily damaged, which produces a greater consumption of gasoline, you must do several tests to determine what the origin of your fault is since it is very difficult to diagnose your car, if you require the manual I have the one of the nissan platine that is equivalent to the clio nothing but I do not know how to upload it.
