Hello friends, I am urgent to get a Pointer 05 manual since I have a problem with one (the motorcycle machine is turned on) I already changed the radiator vulvo but continues to put the same failure ...
I hope and someone can help me find the repair manual of it thanks ...
Hello, what happens with the Fall of the Motaventillator is that the resistance that makes between the first and after second is failing you have to check the resistance that is in the motorcycle of the motorcycle maker I hope the information serves you
Hi Chavez, check the resistance and I did not see any conflict here the problem for me is the relay, of low speed since when I present the fault with the closed switch I went to the releves and with a slight tap (with my finger) I went out the motorcycler ... I will change the low rely and if I see that the problem is normalized I warn you ...
Thank you for your comment and here we walk here! for what you offer from Mty. NL
