DT466E Motor Failure Code
17 years 3 months before #2590 by manual-mecanica
DT466E Motor Failure Code published by Manual-Mecanica
Hello.
Someone can help me get the fault code for DT466E of international trucks and be able to diagnose problems without scanner.
Greetings
15 years 1 month before #13719 by manual-mecanica
Manual-Mecanica Response on the Re: Motor Failure Code DT466E
Hello someone can help me get the failure codes of the international engine DT466E
13 years 7 months before #28456 by manual-mecanica
Hi, would I know if you found the fault codes? Since I have the same engine and I can't get the codes, if you could go through me, I would appreciate it.
