BMW Z3 Manual 1.9 140 hp
13 years 9 months before #26025 by manual-mecanica
BMW Z3 1.9 140 hp manual published by Manual-Mecanica
Hi, I need an owner and workshop of BMW Z3 for 1.9 140 hp engine (103 kW). Thank you very much in advance.
13 years 9 months before #26029 by manual-mecanica
Manual-Mecanica Response on the Re: BMW Z3 1.9 140 hp manual
Friend I bought the BMW Z3 approximately 2 weeks ago ... and I don't even know what kind of oil you can give me some kind of help..thanks !!!
13 years 9 months before #26046 by manual-mecanica
The lubricant to use, depends on the residence zone, (due to ambient temperature). The average ambient temperature, indicates the SAE standard. For example, if the average temperature in winter is 5 ° C or less, I would use a synthetic, SAE 5W40. If the temp. Average is 15 ° C, a semi-synthetic 15W40 can be used.
The first must be replaced each KMS.20,000 and the semi-synthetic, each KMS.8,000, if it is conducted in "sporting" OC/10,000, if it is handled normally. A cordial greeting.
13 years 9 months before #26058 by manual-mecanica
Do you know the oil filter number you use? And what fuel filter? And for a whole, someone put any radio with DVD panel?
13 years 9 months before #26059 by manual-mecanica
I needed to ask for the exchange box oil? What degree of viscosity does it deal with?
