I need manual for a 1994 Ford Tempo
13 years 7 months before #27518 by manual-mecanica
I need manual for a 1994 Ford Tempo published by Manual-Mecanica
Hello friends, I am new in the forum I need a manual for a 1994 Ford Tempo I need to know a problem with the transmission of my car, I do not know if it is skating me or not because I have understood your first change of transmission in the 20 miles and then in the 40s, my car stays like watering and I have to accelerate until you reach 30 or less so that I throw its first change and then I throw it normal in the 40 THANK YOU.
13 years 7 months before #27761 by manual-mecanica
Manual-Mecanica Response on the Re: I need manual for a 1994 Ford Tempo
Hello. Fortunately for you, I have a Mercury Topaz 94. The twin brother of your car. The problem of the transmission you describe is very common in these cars. Inside the tray there is an accumulator piston that over time tends to not work well. Now, you don't tell us if the problem is with the car in cold or if when it is heated. Generally when the failure occurs it is cold and once the normal operating temperature of the transmission is reached, this ceases. It is solved, if this is your case with a simple additive. In my country, ATP-205 is used.
