Ford Focus clutch 2003
13 years 7 months before #27681 by manual-mecanica
Ford Focus 2003 clutch published by Manual-Mecanica
Hello everyone, I am new in the forum and I have read things on the page and it seems quite interesting, I need a clutch manual of Ford Focus 2003, to tighten the clutch cable if you can do not have the clutch so high, if someone can help me I thank you in advance, greetings.
13 years 7 months before #27683 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Focus clutch 2003
Hello, I think in these cars you just have to purge the clutch's sisitema. greetings
13 years 7 months before #27684 by manual-mecanica
Hello, thank you for answering so soon, look at the system, it is already beingch, I think the clutch is bothering me although it still has life, and there is the high pedal with what the car comes out very slowly, what I want is to take a few laps to the screw that pulls the clutch to tighten it and that the car comes out with the lowest pedal, the problem is that I do not know if you have that screw that they have another model of cars and that defect a scheme of the entire clutch route, thanks again
13 years 7 months before #27686 by manual-mecanica
Hello, these cars are already coming with the exact teencion from the factory, maybe it is already necessary that you change your clutch, but you can see in the parate from below (inside the car) if you can regulate it, they have a screw (on the pedal of the clutch) and if you can, adjust it !, But, I think it is time to change the clutch ......... I leave it to your criteria, greetings !!!
