Galloper 2.5 TD Intercoller
13 years 7 months before #27767 by manual-mecanica
Galloper 2.5 TD Intercoller published by Manual-Mecanica
Hello someone can tell me the brands to mount the distribution strap of a gallper with Hyundai D4bh engine
thanks in advance
13 years 7 months before #27773 by manual-mecanica
Manual-Mecanica Answer on the Re: Galloper 2.5 TD Intercoller
Ubica the crankshaft pulley in the mark (t) in the distribution of distribution and from there the cam and the pump are left
13 years 7 months before #27776 by manual-mecanica
Hello, I look at Hyundai, it is relatively easy to change
the distribution strap only as the previous partner says you must look for the T -brand in the crankshaft and take out the covers. What if that engine carries a distribution strap and another of compensator or balancer axis I recommend that you change both and also the tensioners and a separator that has between the two straps.
13 years 7 months before - 13 years 7 months before #27777 by manual-mecanica
I hope this serves you
Last edition: 13 years 7 months before by .
