KA24DE Motor Manual request
13 years 4 months before #31368 by manual-mecanica
KA24DE Motor Manual Request Published by Manual-Mecanica
That such friends I have a Nissan Urvan which I have not been able to repair since I do not have the manual to make the settings and verify the pieces that could be left of other vehicles with the same engine since it has been very difficult for me Similar view with that of my truck is not the same because the altmima is front traction but I would like to know what parts I can take away that they are left to my engine so that I can do of the 2 one and I can make my comioneta I hope and someone can help me and support me with the manual for this engine and if I were not too much to ask for the Altima if it is separately the information.
Greetings and thank you very much in advance
13 years 4 months before #31441 by manual-mecanica
Manual-Mecanica Response on the Re: Request of the Motor Manual Ka24de
What data do you need?
I can give you only the bench settings, connecting rod, valve. But give me the nomenclature of your engine in cm or in inches.
As for you to say they are not the same, of course they are not the same especially because of the engine's disposal.
It is the same only the engine, in terms of exchanging parts ... I doubt it because almost always even if the engine disposal is changed, engine and assassium supports change (water pump or direction, alternator etc.), ladies info. What you are trying to do.
