Reset Timing Belt Toyota Hilux 2006 light
13 years 3 months before #32309 by manual-mecanica
Reset Timing Belt Toyota Hilux 2006 Light published by Manual-Mecanica
Someone knows how is the procedure to reset the time band light at the Toyota Hilux 2006
13 years 3 months before #32310 by manual-mecanica
Manual-Mecanica Answer on the Re: Reset Timing Belt Toyota Hilux 2006 light
I did not know that there was an indicator light for the time band, knew of the oil, air in pneumatic, service but of band I had no idea
13 years 3 months before #32440 by manual-mecanica
To reset the Lus Tbelt of the strap you have to do the following
First start the truck.
Then with the truck on the booty of the board, so you pass from the ODOMA mode (ODOMETRO) to the mode of the belt mileage counter. Then always with the truck on hold the button and then turn it off to the flat.
When you do that, the number 15 will appear, when that happens presses as many times as necessary, until in the odometer you appear 0, when Eos pass again to place the button pressured the button and ready.
I hope I have helped and sorry for mistakes anything send me such a message I explain better
13 years 3 months before #32535 by manual-mecanica
I am going to try it, I warn you if it works but and by chance you do not have the full service manual of the Hilux Vigo as many Argentina or Thai know it I suppose it is the same is
