Daihatsu Move year 198
13 years 3 months before #32385 by manual-mecanica
Daihatsu Move Year 198 Published by Manual-Mecanica
Good to all ... I'm from Cordoba, Argentina. Buy a Daihatsu Move 1998 model three months ago ... In general, it is a very good vehicle, but it has a small failure, I do not know if it is in the escape pipe, or as the mechanic says it is a problem of injectors. Unfortunately here in my province there are no specialized workshops, added to the fact that I am a single woman and since I do not understand much of mechanics, he tells me anything. Please, if someone can give me any data, or the exploded manual would appreciate it infinitely.
I await response and/or comments. THANK YOU SO MUCH!!! Evelyn
13 years 3 months before #32408 by manual-mecanica
Manual-Mecanica Response on the Re: Daihatsu Move Year 198
But what is the fault that your car has?
13 years 3 months before #32432 by manual-mecanica
HELLO...!!! The failure (in my opinion) is smell of raw fuel. A mechanic tells me that they are the injectors, but in another workshop they told me that the injectors are fine, that it can be the catalyst or a loose flange in the exhaust pipe, but nobody discovers where the smell of fuel comes from. That is why I need the manual, to know the number of injectors, or brand or model. I try to explain it with my words, I apologize !!! And thank you very much for answering ... thanks again ...
13 years 3 months before #32445 by manual-mecanica
Hello, the smell of gasoline is at the time of starting or by contacting.
If it is a injection, it may have problems in the step by step by step that is stuck with Ollin.
13 years 3 months before #32452 by manual-mecanica
hello!! The smell is when the vehicle starts up, if I carry the low glass the smell of fuel is very strong and I have a small child ... The computer test says that the injectors are fine, but the mechanic believes that they put some alternatives, perhaps larger ... and the smoke of the escape is white ... If someone has the exploded manual, maybe I can tell me what the measurement of injectors is for my car. Thank you for taking into account my consultation ... Thank you very much !!
