I need manual to change evaporator to RAM
13 years 5 months before #32400 by manual-mecanica
I need manual to change evaporator to RAM published by Manual-Mecanica
I want to replace the evaporator to my RAM 150 of 2004,
13 years 5 months before #32403 by manual-mecanica
Manual-Mecanica Answer on the Re: I need manual to change evaporator to RAM
I can tell you that with the manual everything is not specified, I advise you that if you are going to change it, you have to eat for lowering the steering wheel then the accessories such as Tacometer Repro Lenate glovera
13 years 5 months before #32404 by manual-mecanica
Thank you for answering,
you know about some link or video that guides me step by step. I already bought the evaporator but I need to know specifically which screws release.
My Dodge Ramii is Larami 4x4 ... It has a lot
13 years 4 months before #32423 by manual-mecanica
Not true but you have to look on the side of the bottom of the board there are some screw anyway that hurries taking the accessories you will realize which you have to remove
13 years 4 months before #32426 by manual-mecanica
Friend, disassembled everything you think is necessary, provided you disrupt an important stretch, gather a camera taking photos without risks without risks, squeeze the screws calculating the force used when disarming, if possible leave your threads the screws for minors wrong or lost.
