That such partners of the forum I have a request for you, what happens is that I have a Nissan Tsuru model 93 Mexican model and bring the E16 engine of 8 valves, and I would like to know if there is any manual of this engine, since I have problems because I spend oil and I need the empty and circulation diagram of gases and everything that intervenes, I would appreciate them very much.
Companion Checate the tsuru manual there, what you need already check it and it is very complete, you can also check the motor manual B13 but the same and it does not work for you because yours brings electronic injection, and if you throw Czech oil you reverse it and the seals of the heads, also say that cads that you make tuning you must check it and change different things according to the mileage of your ship !!! greetings!!!
First of all thanks and greetings. The wave is that I just adjusted it and I have checked several manuals but they all bring the chain system, thinking that I would have equated me in time, the pulley of El Tree brings two brands a triangle and a zero What should I put with the zero of the crankshaft pulley?
