I need Ford Orion 97 manual
13 years 3 months before #32410 by manual-mecanica
I need Ford Orion 97 manual published by Manual-Mecanica
Hello, I bought an Orion 97 and it does not have the manual and I get a light on the board (yellow) and I do not know what it is ... Ah something else without counting that starts when you want ... Well I hope someone can pass it to me thank you!
Analia
13 years 3 months before #32411 by manual-mecanica
Manual-Mecanica Response on the Re: I need Ford Orion 97 manual
What figure does that light have ?? It is probably the malfunction of the "Check Engine" engine that is related to the other problem you comment,
can you upload an image of that light that appears on the board? To clarify better
13 years 3 months before #32420 by manual-mecanica
In the Orion a classic failure that is, a breakage of a weld inside the fusera, is linked to the gasoline pump drive.
One of the features is usually the start of erratically.
13 years 3 months before #32439 by manual-mecanica
The light that turns on is yellow when I make contact, it is like a stud with water, a heater would look like that after two seconds he went out and before he was always on is next to the oil light. On the other hand, the issue is that when it sometimes starts, it does to gas sometimes to gas regulates and turns off alone, the coil brings the equal spark plug but it is irregular the operation and what does it in cold and with the hot engine also the fusera does not heat and I have a gas pump filters injector and new tank and clean. And the instrumental of the gas is in a few months ago.
13 years 3 months before #32470 by manual-mecanica
If the fusera this evil does not show it to the naked eye, it must be opened, since what is disrupted is a component.
With sporadic faults it is difficult to realize, you can see if when it does not start, you get current (12 volts) to the gasoline pump connector and the ignition coil.
When this happens they usually start gas, since they have an independent ignition system of the ECU, at this time I have an Orion in the workshop with a total pump current and in ECU, but Gas is fine.
You could control the ignition module, the coil in one of them is failing something like that.
