- Thanks received: 1
06-19-2025 Hits: 725 Technology
Wolfi77 wrote: Greetings Agpppatta, when you turn off the vehicle the rpm needle falls to zero or remains the same in 2500, if the vehicle is kept the same or not, the vehicle indicates that the servomotor was locked or damaged, currently most of the vehicles the "analog" indicators are controlled by the ECU through servomotores, the norm would be to take out the instrument console. From the servo in question, most times said component is replaced.
