Ignition failure when the engine is cold mini
13 years 1 month before #34667 by manual-mecanica
Ignition failure when the engine is cold mini published by manual-mecanica
Happy day colleagues, I have a 2004 mini with ignition failure only when the engine is off for a long space of time, presents a strong draft that gradually disappears after that goes out and turns on again as if it had no problem. The vehicle does not present any fault code and already clean the butterfly of acceleration and the injectors and I put new spark plugs. before hand grace for your collaboration
