Hello, I have the KDJ 90 manual with the 1KD FTV engine, which is the 4000 cc 4000 CC cylinder diesel with 160 hp D4D.
What is the engine is the same changes the electronics and that mine has intrecerer and the 4 runer unless they put it later came out without it. Toyota spends the same engine for a lot of models This is very old, started with 130 hp and the an squeezed is currently taking 220cv but the block is the same, I am here to repair one, I can provide you with info or on the page
www.kdjoteros.com you have all the manuals electrical schemes and explodes in the documents section. If you are yours and you are preparing it, take a look at the Bricos section. Mine and changed a VIELA The Valve Clea Cleaning Cleaning of the EGR and the cooler and Catalyst elimination 15 hp more and was because it was in the admission. Well greeting if you need something here you have me.
