aid
12 years 6 months before #39241 by manual-mecanica
Manual-Mecanica response on the subject helps
If it was a smoke of oil, and even throws that smoke especially when I accelerate it when the engine was installed after everything that was done I have operated it about 30 minutes more less without taking it to the street but the smoke is still according to the type of the teacher should work some good klm so that the new pieces are struck.
Looking up the spark plug, the piston wet with oil is seen after it was done and also if the tube silencer is true, it is wet with oil but what worries me is that the piston still wets. When it works and thanks for the answers
12 years 6 months before #39242 by manual-mecanica
Well the smoke if it is from oil and it is the same as before after everything that was done:( after I denue the engine I have worked about 30 min I have not yet taken it to the street because it throws a lot of smoke, especially when the accelerate is right, the silencer escape is struck etc. The new pieces are struck, this will be true how to go bad to be bad if the engine is almost like new thanks for the answers I can expect?
